Rotate objects
hitya723
I use HD Suite 2016. I created a rail from wrought irom bars but I cannot make the horizontal connection of these bars because the position of these bars cannot be changed from vertical position into horizontal position. Is there a solution to do that?  Thank you. Nelly
Rotating symbols can only be done natively in Chief Architect Premier software.
You can (after some practice and study) download and learn to use Sketch Up software to make things like that using Sketch Up and then export the file for import into Suite. Sketch Up is free to download and use. It is not terribly hard to learn and use but does require some confront and dedicated study but is a great adjunct to Home Designer software.
