Designer_Ryan Posted September 27, 2024 Share Posted September 27, 2024 Over-time, I have changed wall types. Therefore, when I copy/paste and existing drawing into a new drawing I keep getting multiple wall types with _2, or _3 after them. I have selected Delete All Unused walls not used, but since they are being used they won't delete. I have constantly used the object eyedropper to change the walls, then reselect Delete All Unused walls. Sometimes it works, and sometimes it doesn't. Is there a way to somehow be able to choose a wall, select all of those walls at once, then change them to the most current wall, so I can Delete All Unused walls again to get rid of them? Or, is there a better way? Here's a pic to show you. Thanks in advance. Link to comment Share on other sites More sharing options...
Designer_Ryan Posted September 27, 2024 Author Share Posted September 27, 2024 5 minutes ago, Designer_Ryan said: Over-time, I have changed wall types. Therefore, when I copy/paste and existing drawing into a new drawing I keep getting multiple wall types with _2, or _3 after them. I have selected Delete All Unused walls not used, but since they are being used they won't delete. I have constantly used the object eyedropper to change the walls, then reselect Delete All Unused walls. Sometimes it works, and sometimes it doesn't. Is there a way to somehow be able to choose a wall, select all of those walls at once, then change them to the most current wall, so I can Delete All Unused walls again to get rid of them? Or, is there a better way? Here's a pic to show you. Thanks in advance. FYI- I've selected a wall, then Marquee Select Similar, Select All Similar. But, all the walls get selected. Link to comment Share on other sites More sharing options...
solver Posted September 28, 2024 Share Posted September 28, 2024 9 hours ago, Designer_Ryan said: when I copy/paste and existing drawing into a new drawing Why are you doing that and not starting from a template each time? Tell us more about your process. Walls are often connected to defaults and will not be deleted -- program sees them as used. Link to comment Share on other sites More sharing options...
