rcspott Posted April 10, 2015 Share Posted April 10, 2015 Designing a small warehouse with slab foundation and 12' walls. Roof on warehouse is standard gable end roof 4/12. The 12" wall, non gable end, has a normal 3' 0" standard metal entry door. Trying to have a 4'-5' shed roof over that door that comes off the 12' wall at about 9'. No support posts and slab under roof. Can someone point me in the right direction? Thanks Rich Link to comment Share on other sites More sharing options...
solver Posted April 10, 2015 Share Posted April 10, 2015 The simplest way with Pro is to manually draw a roof plane where you want it. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 10, 2015 Share Posted April 10, 2015 you can also make a ROOM out of invisible walls , make the Room 9' high ,set walls for shed roof and give the roof a mono-slab floor/foundation. M. Link to comment Share on other sites More sharing options...
