TimFromSSH Posted May 8, 2024 Share Posted May 8, 2024 I had this working at one time but through a series of floorplan changes, I'm no longer able to get a simple roof to build right. I always seem to end up with offset beams and in this case different height of beam for some reason. Entire house is 96" ceiling height except front section is open to below. There is covered porch on front of garage. Garage is 102" ceiling height. It seems HDS is starting the T Gable to the garage wall and not the covered porch so the beam is offset and also lower as a result... but then the garage design roof takes over and does it correctly. I've tried splitting the house wall into segments or doing one long segment. I've tried to play with ceiling heights and overhangs, but I can't find the magic to make the roof correct. Any help appreciated. (I can't attach the design file as even if I delete everything non-relevant it is still 19MB). Tim Link to comment Share on other sites More sharing options...
y-g-m-n Posted May 9, 2024 Share Posted May 9, 2024 GEt pro and then manually edit those automated roof planes to get what you want. Link to comment Share on other sites More sharing options...
Jo_Ann Posted May 9, 2024 Share Posted May 9, 2024 The 2d floor plan image does not match with what you described. is the porch in front of the garage the "open below" room? Have you made sure all the interior rooms (including closets) are set at 96"? Is it supposed to look like this? Link to comment Share on other sites More sharing options...
