cnbuckley Posted April 9, 2015 Share Posted April 9, 2015 Hi there I am new to the program and site I currently have home designer suite 10 and I have been getting on fine until I try and build a roof there are two major issues. 1) As you can see from the photo below, I have a semi - detached house with a main shed or half gable roof. Currently there is a single storey extension on back with a shed roof coming parallel off. When I add the four walls at the back of the main property for this extension and put the roof on it automatically puts three walls up to the second floor which I don't need. Please help how I delete these three walls. 2) Issue two is I would like to model an extension with two storey gable end as per the image shown in 2 however I can't work out how to do it, I have made the current structure however putting the extension and roof on it just mades the walls and roof the same size as the main hous, please help thanks chris Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 9, 2015 Share Posted April 9, 2015 What you are observing is merely how the software operates (it creates attic walls automatically). There is no "reason" for this other than that is the way they programmed it to function. See this short You Tube Video done in Suite 10 please: http://youtu.be/lVy6-m-2ImY DJP Link to comment Share on other sites More sharing options...
cnbuckley Posted April 9, 2015 Author Share Posted April 9, 2015 Hi DJP really appreciate you looking into this for me, this has answered question 2 excellently, my question 1 was making the single storey extension off the main house with a sloping or shed roof with out the automatic additional walls. Is this done in the same manner or is it a different way? A picture of this is attached, thanks v much again chris Link to comment Share on other sites More sharing options...
Kbird1 Posted April 10, 2015 Share Posted April 10, 2015 try making the single storey addition 6" narrower than the main house and the software should do it ok, it seems to have an issue with additions that are exactly the same width as the main building , as it then thinks the addition is the main house and tries to merge the rooflines. M. Link to comment Share on other sites More sharing options...
