Blazer76 Posted March 31, 2024 Share Posted March 31, 2024 I have a wall that I want to have it stop at around 8ft standard ceiling height so I can leave the top of it open to the cathedral ceiling for storage up above. I'm able to create the wall but I can't get the walls to be just 8ft with a loft area above for storage. I have the Suite version and have attached the walls I want to be short. Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 31, 2024 Share Posted March 31, 2024 On the attic level, check 'invisible' on the attic wall. On level 1, open each of the small rooms, and check the boxes for ceiling over this room, shelf ceiling, use soffit surface for ceiling. Link to comment Share on other sites More sharing options...
y-g-m-n Posted March 31, 2024 Share Posted March 31, 2024 highlight one of those rooms. Click EDIT or open go to STRUCTURE tab Click help button lower right Read help about ceiling - especially SHELF CEILING I mean the help for Shelf screen explains you issue to the T From the help screen on SHELF CEILINGS Quote Shelf Ceilings In rooms with high or vaulted ceilings, it is possible to have a smaller room such as a closet that has a flat, lower ceiling. By default, the area above the flat ceiling will be enclosed by automatically-generated Attic walls. See Attic Walls. If you prefer, you can specify that these Attic walls be suppressed and an open space be created instead. This condition is referred to as a Shelf Ceiling, or plant shelf, and can be specified in the Room Specification dialog of the room with the lower flat ceiling. See Structure Panel. Link to comment Share on other sites More sharing options...
Blazer76 Posted March 31, 2024 Author Share Posted March 31, 2024 You guys are awesome, thanks so much! Link to comment Share on other sites More sharing options...
