How can I create a cabinet door with a round opening (circle)
divabydesign
I am not finding images if what I want online to better illustrate what I need. I am designing a base cabinet as a cubby for a dentist office. They want a "reading nook" for children so the base cabinet would have an opening that is a circle. I can't find how to create that or a work-around in Home Designer Pro 2023. Thank you!
Without seeing what you are thinking of, would a lower than usual height base cabinet for the bottom seat, and then an arched opening above the cabinet work? Raise the opening's sill to the top of the cabinet and then go from there?
