Casey4965 Posted January 27, 2024 Share Posted January 27, 2024 I am not sure what I am doing wrong. I have not had this issues before. 1. I need tile to wrap around a full height wall just above the pony wall that dies into it. 2. The room divider will not separate the shower from the main bath. I have included the plan file and two snippets. Thank you in advance for all advice. And I hope I have posted this correctly, with enough information. Casey Skelton Home Designer Pro 2024 Burnside Master Bath.plan Link to comment Share on other sites More sharing options...
solver Posted January 28, 2024 Share Posted January 28, 2024 2 hours ago, Casey4965 said: 1. I need tile to wrap around a full height wall just above the pony wall that dies into it. Custom Backsplash 2 hours ago, Casey4965 said: 2. The room divider will not separate the shower from the main bath. Make the shower pony wall No Room Definition, then drag the Room Divider across to the far wall. For some reason, these two wall types do not always join as we want. 2 hours ago, Casey4965 said: And I hope I have posted this correctly, with enough information. Thanks -- you did. Link to comment Share on other sites More sharing options...
Casey4965 Posted January 28, 2024 Author Share Posted January 28, 2024 Thanks Eric. I have tried this multiple times and the rooms will not divide. I have made the pony wall on the left with no room definition, as well as the right and then both and still no separation. Link to comment Share on other sites More sharing options...
solver Posted January 28, 2024 Share Posted January 28, 2024 17 hours ago, solver said: then drag the Room Divider across to the far wall Did you do this too? Link to comment Share on other sites More sharing options...
Casey4965 Posted January 28, 2024 Author Share Posted January 28, 2024 This is where I have dragged it to. See attached. Link to comment Share on other sites More sharing options...
solver Posted January 28, 2024 Share Posted January 28, 2024 Link to comment Share on other sites More sharing options...
Casey4965 Posted January 28, 2024 Author Share Posted January 28, 2024 Eric, I did that same thing multiple times, and it did not work. Now I did one more time and it did. I am not sure what happened but thanks so much. I also did the custom backsplash and it worked perfectly. Thanks again. Casey Link to comment Share on other sites More sharing options...
