Trying to get better quality Physically Based views
4ndrew
I am having a hard time getting the Physically Based materials to look as expected.
Here is a comparison of Standard and Physically based views of the same materials in a room with a single wide window providing light.
The materials in Standard look much closer to the previews, and as expected.
Even with some adjustments, I can't get the colors to look correct in Physically Based, as well as getting far too much reflectivity on something like floor tiles (applied as wainscot to test here):
Standard:
Physically based:
Any suggestions?
Thanks
20 minutes ago, y-g-m-n said:
go to the specific tile material and edit it. I think on second tab is where you can set surface from Matte to shiny and other things to adjust how it looks in real world.
Thanks - tried that. Here's what happens when I set Shininess to "Dull":
So, it seems to have almost no effect. Maybe actually makes it shinier.
Another angle, not what I'd typically describe as "dull":
looks fine to me in my HD2024:
View is Perspective Dollhouse using Physical based.
Note look normal in Standard too
I checked material file and it was fine other than DULL not checked.
How do you have SUNLIGHT set?
I played with that and noticed if I could change appearance by messing with LUX and angle.
Lux had to increase by 1000 times though so it was around 100,000,000 which is crazy not normal number.
ygmn_wainscottest.pdf
FYI: I noticed you use Wall Covering to apply tile.
I would have installed the tile using custom back splash so you can get the proper thickness.
OR made a new wall type for this tile portion and then use Pony wall where you want the tile.
As you have it the tile has no thickness.
I feel Wall covering meant for wall paper or you can use for paint if you want a 2 color or more wall.
Thanks, but I need to troubleshoot the materials for now. This file is just a test.
Thanks again, but I'm not using 2024. I'll contact support.
