drew house but trying to swap wall heights on 1st & 2nd floors...
toddjanzer
I drew a 2 level house & I want the 1st floor wall heights to be 8' high & the 2nd floor wall heights to be 10' high... Right now they are reversed. Note: I changed the heights in the default section, but when I click on the framing members in framing view, the dimensions haven't changed as I specified. I'm wondering if I need to have the program redraw or refresh to register the changes?
Go to Edit>Reset to Defaults
This image if from Chief, so you will not have all the same options, but check the ones shown that you do have.
You need to rebuild framing (or have Auto Rebuild framing on) if framing does not change.
