Cabinetry Manipulation
Casey4965
A useful faking trick I've used in similar situations is to make specific components have the material "Insulation Air Gap".
In the below, the left cabinet (full ht, opening top and bottom) is normal.
The middle cabinet I used material painter to make the back "Insulation air gap". That seems to remove top and bottom as well, but leaves the front frame as well as the opening shelves.
The right cabinet I also turned the front frame into air gap.
In both, note the middle shelf is part of the same component as the top and the bottom, so got zapped as well. You could avoid that by editing the cabinet to have only one tall front opening, not two. Also, the side panels got zapped, so I manually added vertical partitions the same height in the place the side panels should be.
  • 3 weeks later...
