Pony Walls and Caps
Casey4965
I have been learning quite a bit about the software and appreciate the help I have received thus far. I have been following some of Eric's videos and these have been most helpful.
I am having issues with the cap on a pony wall. I want to remove the existing cap and replace with my own.
Casey Skelton
Home Designer Pro 2024
Pony Wall.planFetching info...
      I cannot tell from what you posted what you wish the outcome to look like. Chief Premier has what you want (a wall cap tab in the wall specification dialog) but Home Designer Pro does not.
      However you can use a soffit, reshaped and located to emulate what you are after or perhaps a custom slab. Also soffits can have molding profiles applied to them to add more creative choices. What you came up with is quite creative as well.
