Casey4965 Posted October 27, 2023 Share Posted October 27, 2023 I have been learning quite a bit about the software and appreciate the help I have received thus far. I have been following some of Eric's videos and these have been most helpful. I am having issues with the cap on a pony wall. I want to remove the existing cap and replace with my own. Casey Skelton Home Designer Pro 2024 Pony Wall.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 27, 2023 Share Posted October 27, 2023 I cannot tell from what you posted what you wish the outcome to look like. Chief Premier has what you want (a wall cap tab in the wall specification dialog) but Home Designer Pro does not. However you can use a soffit, reshaped and located to emulate what you are after or perhaps a custom slab. Also soffits can have molding profiles applied to them to add more creative choices. What you came up with is quite creative as well. DJP Link to comment Share on other sites More sharing options...
Casey4965 Posted October 30, 2023 Author Share Posted October 30, 2023 David, I figured it out. I just opened up a blank plan and was able to adjust the pony wall to do what I needed. I then copied and pasted into my plan. Thanks, Casey Link to comment Share on other sites More sharing options...
