Walls not connecting
Trueburton
The software is programed to auto-generate via that built in routine but one can go to the attic level and manually draw any walls that do not make sense. But when doing so, you also have to open the Wall Specification dialog of each manually drawn wall and set the checkboxes "Attic Wall", "No Room Define" & "No Locate" like auto-generated walls.
On the other issue what is showing on the foundation is NOT an auto-generated wall IMHO. It is probably a wall that needs its Wall Polyline manually adjusted using a back-clip elevation camera created 90 degrees to that offending wall.
