aleohio Posted June 10, 2023 Share Posted June 10, 2023 I'm helping a client/friend with the design of their home. They want an underground garage that is partially under the house and partially under a patio. - no problem, the town allows it and the HDPro 2024 software can do that. The terrain and terrain hole aren't a problem eithery. They sent me the picture that inspired the idea. The problem is, I can't find the right way to put in the ramp and retaining walls of the driveway. I tried putting a terrain flat around the house and the drive and terrain elevation lines going down the drive to a lower terrain flat, but it turned out a lumpy mess. PS. Caution about looking for the source of this screenshot of drone footage. Link to comment Share on other sites More sharing options...
Solution Garybills Posted June 10, 2023 Solution Share Posted June 10, 2023 Are you looking for something like this? 1 Link to comment Share on other sites More sharing options...
Robborito Posted June 10, 2023 Share Posted June 10, 2023 So what is the solution here - so marked? Like - one can read some notes on the plan - but there are no suggested directions to achieve the result so deemed as a solution? Good luck. Link to comment Share on other sites More sharing options...
Garybills Posted June 10, 2023 Share Posted June 10, 2023 Sorry for not giving any details to my example but it was late and past my bedtime!! Step to my example 1: Draw 1st Floor plan 2: Draw Basement at 120” below 1st floor 3: Build Terrain with subfloor 12” above terrain and elevation lines set at 0” at the front and back 4: Add terrain region in front of basement garage set at -120” 5: Draw retaining walls in the shape of driveway Added 6: Added terrain regions at 0” and shaped to match retaining walls and around the house 7: Drew terrain feature for driveway 8: Adjusted Lower terrain region to gat driveway even with basement floor 9: Changed fill colors to show different regions Link to comment Share on other sites More sharing options...
Robborito Posted June 13, 2023 Share Posted June 13, 2023 OK - so I've read the book - when is the movie released? Link to comment Share on other sites More sharing options...
