Dormer Roof Material
MississippiMims
Go to solution Solved by DavidJPotter,
  • Solution
A dormer does not have a "Material Tab" so what can be done is to create a camera view (full or overview), then using the "Material Spray Can" tool select the roofing material you wish and then apply it to the dormer roofs and ridge trim. Or you can "explode" the dormer symbol into its parts and then the roof planes of the dormer can then be accessed using the dormer roof plane dialog-Materials Tab like any other roof plane.
