AudunA Posted March 11, 2023 Share Posted March 11, 2023 Hi Why is the wall framing shown in the window. I have tried placing it both in atic and 2.nd floor. Home Designer Pro 2019 Build 20.3.0.54x64 Regards Audun Kjøkken ved gang Rett trapp.plan Link to comment Share on other sites More sharing options...
Garybills Posted March 11, 2023 Share Posted March 11, 2023 I downloaded your plan and unchecked attic wall on that wall, and it reframed it correctly. Link to comment Share on other sites More sharing options...
Garybills Posted March 11, 2023 Share Posted March 11, 2023 23 minutes ago, Garybills said: I downloaded your plan and unchecked attic wall on that wall, and it reframed it correctly. The attic wall is the wall I changed Link to comment Share on other sites More sharing options...
Rookie65 Posted March 11, 2023 Share Posted March 11, 2023 You can check your framing defaults to see if you have auto rebuild walls checked or not. That is often the culprit Link to comment Share on other sites More sharing options...
AudunA Posted March 11, 2023 Author Share Posted March 11, 2023 Thank you very much. That solved some of the problems I have had. But when I added the complete window layout I still get an issue on the middel windows. Any suggestion to fix this as well? Regards AudunKjøkken ved gang 2.4.plan Kjøkken ved gang 2.4.plan Link to comment Share on other sites More sharing options...
Garybills Posted March 11, 2023 Share Posted March 11, 2023 The windows are splitting two walls and the framing you’re seeing now is the 2nd floor wall which is really short. I’m not sure what’s going on with that. Link to comment Share on other sites More sharing options...
AudunA Posted March 11, 2023 Author Share Posted March 11, 2023 I experimented with the horizontal spacing of the larged squared windows on the 2nd floor and it looks like that are affecting the behaviour. I will keep experimenting to see if I can find the solution. Audun Link to comment Share on other sites More sharing options...
AudunA Posted March 11, 2023 Author Share Posted March 11, 2023 The strage thing is that if I remove one of the squared windows in the 2nd floor the problem disapears. Link to comment Share on other sites More sharing options...
Garybills Posted March 11, 2023 Share Posted March 11, 2023 I’m not at my computer now, but you might try grabbing the bottom of the upper wall and pulling it down below the windows. Link to comment Share on other sites More sharing options...
Garybills Posted March 11, 2023 Share Posted March 11, 2023 That’s strange Link to comment Share on other sites More sharing options...
AudunA Posted March 11, 2023 Author Share Posted March 11, 2023 Pulling down the wall did not resolve it. Link to comment Share on other sites More sharing options...
Garybills Posted March 11, 2023 Share Posted March 11, 2023 6 hours ago, Garybills said: The attic wall is the wall I changed I just got to the computer. I selected all the upper windows in an elevation view and copied them. deleted the wall with the windows, grabbed the top of the short wall and pulled up to the ridge. then in plan view went to edit toolbar, paste hold position to put the windows back in the wall. break the top of the wall at the ridge and pull the ends down below the roof. Link to comment Share on other sites More sharing options...
AudunA Posted March 11, 2023 Author Share Posted March 11, 2023 Thank, worked like a charm. 1 Link to comment Share on other sites More sharing options...
