Kristine Posted March 9, 2023 Share Posted March 9, 2023 Hi there. I am trying to make the walls in this room with a vaulted ceiling all the same colour, but I can't get the area in the vault (above standard ceiling height) to show the colour correctly. There is a material clash which is causing it to glitch and look patchy. I've tried to select the areas individually though can't. Any ideas much appreciated thanks. Link to comment Share on other sites More sharing options...
y-g-m-n Posted March 9, 2023 Share Posted March 9, 2023 grap eye dropper and select the color of the I am guessing grey walls you want to place in the catherdral ends. then you get a spray can - Select either componen or room to put spry can on portion you want with this new color and it will change. Check HLP on spray can to get more info on option... Link to comment Share on other sites More sharing options...
Kristine Posted March 9, 2023 Author Share Posted March 9, 2023 Thanks. Yes, I'm very familiar with the spray can tool and have already done that though it's conflicting with another material which is why in the screenshot it has this hazy look which jumps between colours. My thought is simply to add a backsplash right up to the ceiling though I wondered if there was a more appropriate way to make it work. Link to comment Share on other sites More sharing options...
