Nirvana Posted March 17, 2015 Share Posted March 17, 2015 I'm new to Home Designer Suite 2015, but I have made a great deal of progress on my custom home design in a very short time. This has been a fantastic tool. I am having a minor issue with the interior trim for my doors. All of my doors seem to have a "crown" that I can't seem to change. I'm trying to stack a transom window on my doors as I've done with my windows, but I can't seem to figure out how to make the trim plain. I was able to select a "modern" window style and use that for stacking transoms on my windows. I'm posting a picture to show the issue. Any help would be greatly appreciated. Thanks in advance. Link to comment Share on other sites More sharing options...
katalyst777 Posted March 17, 2015 Share Posted March 17, 2015 The Lintel is probably related to the plan style template that you started with, and you probably can't remove it in Suite. Looking at the pictures for the template styles, it looks like it could be Today's Traditional, Colonial, or Arts & Crafts. You can start a new plan using the default or another template style which doesn't have it set. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 17, 2015 Share Posted March 17, 2015 In certain Suite plan templates you get that kind of trim on doors and windows. Use a different template or live with the attributes of the template you choose. You would have to have Home Designer Pro or Chief Premier to do better. DJP Link to comment Share on other sites More sharing options...
Nirvana Posted March 17, 2015 Author Share Posted March 17, 2015 Thanks for the quick replies. I was afraid it was a template setting. That's unfortunate that I can't easily make a change. I have a lot of work put into this design. Is it possible to export what I've done, create a new project using the standard template and then import my work? That way I'd just need to redo my doors. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 18, 2015 Share Posted March 18, 2015 So in Suite you can't change the casing of a Door in the Door's DBX ? or suppress the Lintel if on? I have Pro and can change the style , size etc , (or set it up in the Plan Defaults too.) You can copy and paste between Plans ( can use "hold Position" on paste), however I don't think Suite has Edit>Edit Area>All Floors to simplify this. might want to check your reference manual (on the help menu) and see Link to comment Share on other sites More sharing options...
Nirvana Posted March 18, 2015 Author Share Posted March 18, 2015 I found a solution. It was actually suggested by katalyst777 in another thread from 2006. I created a new plan using the default template. I then added a door, copied it, closed the plan, opened my other plan and pasted the door. It was very tedious, but it did work. I can't seem to post the revised image though. 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted March 18, 2015 Share Posted March 18, 2015 Glad that my past self could be of help! I apologize for forgetting that solution though, time to add it back in to my mental repertoire! Link to comment Share on other sites More sharing options...
