object rotation handle
Chelanman
Go to solution Solved by ChiefArchitect,
I'm in Home Designer Pro 2022.  I often have difficulty finding the rotate handle when I highlight an object.  I guess it's gray by default; so it often "hides" among the other gray objects in the area.  I can always find it eventually but it's sometimes like searching for Waldo.  Is there any way to make this thing more prominent:  Like making it bigger or changing the color of it to something bright?  Thank you.
  • Solution
Hi Jim,
In user Preferences, there are controls to change the default handle color and fill color.
Go to Edit>Preferences>Appearance>Colors to see the options.
Try out a few of these settings and let us know if it helps!
If you feel link there should be other settings, please let us know and we can consider those for future improvements.
