TedderRCG Posted August 26, 2022 Share Posted August 26, 2022 Has anyone else noticed that with Home Designer Pro 2023, when I draw exterior walls it is removing the last 1/2" of OSB at the end. When I start the next wall, it starts from the end of the first wall's osb which is 1/2 short causing the overall wall lengths to be 1/2" shorter than I expected. Is there an easy fix for this? See screen shot of wall below. Pro 2022 does not do this. It only started happening when I upgraded. Hoping it is a simple setting but I have tried preferences and default settings. Link to comment Share on other sites More sharing options...
TedderRCG Posted August 26, 2022 Author Share Posted August 26, 2022 Thanks Eric. First time using this forum and appreciate the feedback. I have used the knowledge base many times but cannot seem to find this issue. It only began when I first started using Home Designer Pro 2023 and was hoping that someone else ran across the same issue. I am using my same template that has all of my default settings and preferences that I just brought into 2023. I can go back to 2022 and this does not happen. Just cannot seem to find the solution. Link to comment Share on other sites More sharing options...
solver Posted August 26, 2022 Share Posted August 26, 2022 Here is what I see. It's often helpful to have a simple plan file to review that demonstrates the problem. Exit from the program before you attach, and there is a 14MB file size limit. Link to comment Share on other sites More sharing options...
