Designer_Ryan Posted June 9, 2022 Share Posted June 9, 2022 I'm trying to match Home Designer Pro drawings to my AutoCAD drawings, so some sheets can be drawn using AutoCAD and some sheets can be drawn with Home Designer Pro. Watching this video (time 2:25) https://www.chiefarchitect.com/videos/watch/5516/what-s-new-in-x13-drafting-project-management.html?playlist=177 How can I change the rotation of the dimension text in Home Designer Pro? Link to comment Share on other sites More sharing options...
Solution solver Posted June 9, 2022 Solution Share Posted June 9, 2022 Home Designer does not have this feature. Link to comment Share on other sites More sharing options...
Designer_Ryan Posted June 9, 2022 Author Share Posted June 9, 2022 13 hours ago, solver said: Home Designer does not have this feature. Can I remove the dimension so I can just add a text? Link to comment Share on other sites More sharing options...
solver Posted June 9, 2022 Share Posted June 9, 2022 You can mask the numbers and/or cover with your own text. I'll suggest this is generally a bad idea as changes to the drawing will not be reflected in the dimensions. Link to comment Share on other sites More sharing options...
