Roof Trusses in Suite
northmark2002
Is it not possible to create roof trusses in Suite?  It frames any roof with conventional framing, which of course is not the way things are generally done.  Even a 60' wide building with an 8/10 pitch generates 80' long rafters instead of trusses.  This may be a limitation of Suite but that is not explained anywhere.  Thank you.
