cfichter Posted February 3, 2022 Share Posted February 3, 2022 Hello - new to Home Designer - quick Q - I have gone through the pdf tutorial and watched videos, and getting dangerous with designs I discovered the space planning tool - super handy design tool to quickly mock/sketch up a house design. However - it does this wierd thing - when I select 'build house' and then have a look in camera view, it creates these deck structures with pier/cement footings and support trusses that I did not create. Why is it doing that? There is no way I can see to remove them - only visible in camera view - not visible in the plan, no way to select them and remove them that I can see. Thanks Link to comment Share on other sites More sharing options...
cfichter Posted February 3, 2022 Author Share Posted February 3, 2022 Thank you very much for the assist! Done (sig) and thx for the starting links. Attached is what I'm seeing - mockup of 'room boxes' using 'Space Planner' tool view in plan view after build (no decks/structures) view in camera view after build (deck structures visible can't remove) I did at one point have decks and patios back there, was experimenting and deleted them. I tried check plan but didn't find anything/fix anything. Thx for ideas. Link to comment Share on other sites More sharing options...
solver Posted February 3, 2022 Share Posted February 3, 2022 On 2/3/2022 at 5:15 PM, solver said: and version (2018, 2019 etc) Expand The version is key too as the program changes year to year. Edit>Delete Objects Choose Deck Framing Link to comment Share on other sites More sharing options...
cfichter Posted February 3, 2022 Author Share Posted February 3, 2022 Very cool, ty Solver that worked - although, it left the round cement pier things that support the deck posts - I don't see what those are listed in objects to delete - I experimented with a few but they weren't removed. Link to comment Share on other sites More sharing options...
solver Posted February 3, 2022 Share Posted February 3, 2022 You may need to delete, then rebuild the foundation. Build>Floor Link to comment Share on other sites More sharing options...
cfichter Posted February 3, 2022 Author Share Posted February 3, 2022 Woot! ty VERY much. Ok g2g - that solved it. I'll definitely be reviewing everything you posted before jumping into the forums again - ty! Link to comment Share on other sites More sharing options...
