Kenster Posted January 16, 2022 Share Posted January 16, 2022 Hi, I am using Home Designer Pro 2022 but this is an issue I haven't solved in previous versions either. I am designing a square cabin with 2 push outs, and a 1 inch ceiling height second floor. The first floor has 9 foot walls. At this point everything from the roof line is as expected as seen in the attached photo. I then add a screen porch on the end of the cabin and add a roof. All fine after this step as well. However, when I go to add a flat ceiling under the porch roof the software does create the flat ceiling but I get a crease now in the main roof line as seen in the second attached image. I can't figure out how this are linked and have run out of ideas on how to fix this. Any insights would be greatly appreciated. Ken Link to comment Share on other sites More sharing options...
Kenster Posted January 16, 2022 Author Share Posted January 16, 2022 Sorry I haven't updated my software. It is Pro 2022. Link to comment Share on other sites More sharing options...
solver Posted January 16, 2022 Share Posted January 16, 2022 Don't know why the program is doing that, but think about how you could correct it. What dimension could you change to make the ridge align? Link to comment Share on other sites More sharing options...
