Connecting Walkthrough Paths
JessieJayne
I am having troubles creating a walkthrough path. I can make camera 1 and camera 2 but as soon as I want to make another spline line they will not connect and a new camera shows as 1 when I would like it to connect to the first line and be camera 3. Any help would be greatly appreciated!
  • 2 months later...
I had the same issue and You Tube did not help.  After much searching in the online help I found "Object Snaps".  It needs to be "On" when you create your Walkthrough path.
On the main menu bar use "Edit" > "Snap Settings" > "Object Snaps"  or you can use "Shift S".
Hope this helps!
