Moving layers.
MississippiMims
Go to solution Solved by solver,
I'm searching for a way to have items display on a different layer.  Specifically, I want an attic wall from a dormer to display on the attic layer instead of the second floor.  (Solver you mentioned this before but I have been unable to find a way to do this)  Another instance is when I turn a weight bearing wall into a foundation wall to produce a footing, I would like the footing to display on the foundation layer instead of in the floorplan.
Wes
  • Solution
You seem to be asking about levels and not layers.
Cut and paste walls from one level to another.
You can do this with Reference Display, but there is a bug and the footing outline is missing the end lines.
You could draw your footing manually on the foundation level and turn off the footing display for levels above.
