What happened to my layout plan? Scroll bars? Zooming out?
BCMike
Hi,
Using Home Designer Pro 2022. It only happens in this one layout plan, everything else is fine.
When I open it, it is literally a dot on the page. The only way that I can find it is to search for text on the page. I then zoom and zoom and zoom until it is a reasonable size. If  I then try to use the scroll bars at all, it apparently scrolls drastically, to the point where the plan seems to have disappeared and I can't even find it without again doing a text search.
Any ideas would be greatly appreciated!
What are you calling a "layout plan"?
Pro has the ability to create Layouts, which are separate from the plan file.
You might try Window>Fill Window Building Only
And it's often helpful to attach the plan file after closing Pro. Allows someone to troubleshoot.
I've not seen this problem and do not know what's causing it.
Try this.
Open the layout, marquee around it to select everything, and Copy.
Close the layout.
Open the plan and send to layout.
Marquee around the entire layout and Delete.
Paste/Hold Position.
Save as a new name.
Close the Layout.
Reopen the Layout. Does it look normal? Double Click the layout box that shows the plan to open the plan file.
