Chris_M Posted December 21, 2021 Share Posted December 21, 2021 Hello, Can anyone suggest how to prevent the black lines from appearing where two different wall types are connected? The screenshot attached shows the issue. In this property we have stone walls all round with studs and insulation (the dark yellow) on the inside, however the insulation stops before the wall shown at the bottom of the image hence why there is a different wall type being used there. How can we prevent the black line from showing? Version: Home Designer Pro 2021 Thanks in advance, Chris Link to comment Share on other sites More sharing options...
solver Posted December 21, 2021 Share Posted December 21, 2021 Link to comment Share on other sites More sharing options...
Chris_M Posted December 21, 2021 Author Share Posted December 21, 2021 @solver Thanks for the suggestion. When I turn on display of "Walls, Through Wall Lines" (this was originally turned off) I get an additional section of black line as below: Any idea how to prevent this? Thanks again. 1 Link to comment Share on other sites More sharing options...
