Reverse and combine a floorplan
StephenF
I own several duplexes and 4 plexes and the units are mirror images.  I want to draw one floorplan and then combine it with a reversed copy of the same floorplan, rather than having to draw it twice.  Please help.
That is do-able but hard to describe just using this forum. It takes several precise actions to pull off successfully. I have done it successfully doing apartments, duplexes etc. I suggest you make a copy of  your existing plan and then experiment combining, reversing and combining your structures and if you mess up, you can start over with the original plan file (you probably  will make some rookie errors (anyone would), so keep a back up to fall back on.
I figured out how to reverse the plan (easy), so I have right and left handed mirror images saved as separate plans.  I have not been able to figure out how to import or combine the right and left into one plan,.  I tried copy/paste, but could not figure out how to copy paste all the features/objects in the plan.
Steve.
