specialk89 Posted September 3, 2021 Share Posted September 3, 2021 Hey All, Question regarding Home Designer Pro 2021. I have the basement framing completely drawn out, and want to make a small change to the foundation heights. Whenever I want to layout my basement framing I get a message that reads "Cannot draw new wall then Auto Rebuild Foundation is turned on" and then makes me proceed to turn it off. Is there anyway to make changes to my foundation height while retaining the basement framing? When I do turn make the changes to foundation with auto rebuild foundation on, it deletes my basement framing. Just curious as to whether there is an easier way besides manually adjusting my foundation wall (need it an extra 6" down to accommodate for slope of ground. Thanks, K Home Designer Pro 2021 Link to comment Share on other sites More sharing options...
solver Posted September 3, 2021 Share Posted September 3, 2021 14 minutes ago, specialk89 said: I have the basement framing completely drawn out What are you calling "basement framing"? If you have added walls or other structure to the foundation, then Auto Rebuild is off. Have you tried changing the defaults for Level 0? 1 Link to comment Share on other sites More sharing options...
BearCreek Posted September 8, 2021 Share Posted September 8, 2021 The foundation level, level 0, is that the same as the basement level? I am drawing interior wall in level 0 and can't select an interior door. Can anyone tell me what I am doing wrong? Link to comment Share on other sites More sharing options...
