Decorative exposed truss below vaulted ceiling
deerwood8
Trusses require a flat ceiling to be created at all (no ceiling = no truss) so the thing to do is to replace the flat ceiling in your room, set up the defaults on the kind of truss you want, create the trusses, lock the truss layer then remove the flat ceiling. I have done this many times but it must be done in the proper sequence as I laid it out above in order to work.
this KB Article may help but I am not sure  HD can model a double trusses roof , ie a scissor truss with the decorative truss under it.
What David meant was that the PROGRAM needs a roof and a flat ceiling to model a truss , it wont build otherwise, you then later remove the ceiling from the room, see the KB Art. it should enlighten you.
http://www.homedesignersoftware.com/support/article/KB-00417/
