SandraH Posted August 11, 2021 Share Posted August 11, 2021 Hi All, Wondering if anyone can look at this file and tell me what has gone wrong with my roof? I created a second storey that I want to sit low (a la Frank Lloyd Wright), but the program created all these weird roof lines, and lowered ceiling. There will only be living space over part of the house. My walls disappeared, and I can't get the roofline to work properly. Not sure what's going on. Thanks Austin-v2 elevation.pdf Austin-v2 2plan.pdf Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 11, 2021 Share Posted August 11, 2021 Please, with Home Designer turned off, attach a copy of your plan along with your intended ceiling heights for the first and second floors, then someone can advise you as to what to do. Wrong settings always obtain wrong results. DJP Link to comment Share on other sites More sharing options...
SandraH Posted August 11, 2021 Author Share Posted August 11, 2021 Thanks David. My main floor has 9' celings, and the second floor will have 7' celings. Right now I have them set to 6' only because I was attempting to get a visual for the client. We may need to still play around with the roof, but right now I need to start with the concept. Austin-v2.zip Link to comment Share on other sites More sharing options...
SandraH Posted August 11, 2021 Author Share Posted August 11, 2021 Link to comment Share on other sites More sharing options...
SandraH Posted August 11, 2021 Author Share Posted August 11, 2021 Fixed it by deleting the floor and re-building. But the reason I had floor set to 6' is because we haven't decided on half storey or full storey, so I was trying to show them the difference in design. Most likely will go with half storey, as the neighbourhood is mostly bungalows, with a few half storeys thrown in. Link to comment Share on other sites More sharing options...
