changing the terrain after the house is completed
JoAnnWodke
I have Home Designer Architectural 2021, my house is mostly done on the software but my elevations are off quite a bit. How do I make those changes now?
I'm trying to decide on patio or deck options and it just wont look the same without correct elevations.
Any help is much appreciated.
Thank you
JoAnn
NYz0INgK46G1QqY08CRCgg3uqA0-cDwOZtdY52iJ-IURCxGu91Vsb8lm_o5h_Mf0Fl0GIgpVOgZFgxSzzliUO2r3BCHisER-obQcZz4r37R-OJpptu4zub6BuunWBFmRBPRpKPIxNQss1owtUAWmteEKLs4KnNwcExsWefc9o9wTgql-GTJ8H78j3U-l-676S6AA8oIJHcQPSERnMpSmDHyIxwpDgWmUhHgKks9yp5JZfll-gezKSM8K6vcGx0-J_iAgDdlsZKmBQJOoYxYAkVR7FL0CvVzwMkeksccjrUmN1AtJxOhY0S2xuo__zDIdBcTYYsGugdgDNKC25KxV8iKrxKSdPWKwhkuRuTHnxXKo1KVK491-E6lvsdEDw885sJovPgdkDEpJAXU4_MuNGZuKlev4zKsXt2UzUMOzXBGwxHYL7jfZd7HoRo8ArQZVxJKUInpvFjQp12bWqSSv0lRaS0S7Z9LDm1WceETSGKrHaDJphRmBC1xNlm1znSanNv6zBEY2qaREmQ403O57d67-ZEqClNDzfqWJEPg7URszF_qQP3HOflkJ9GrrO1QFC24TYxG3g9VUVfzN764W1OCn9aHYrRwG2ZcwNxjMFoXpXYx0SFZubHu2LR8qN1fBfhc2tZoHia5exzHwSStSBSR2qOF4V-8uiGCAG9s5G35TN8XqqP6QQqTssbW2Y_dJLNKDxmXYboKfFPS_DEEIM44P=w1376-h1032-no?authuser=0image.thumb.png.9906e730f1933ca1ebf06b2245ea4087.png
image.thumb.png.43a107301f6c02236782ad1567f09de6.pngimage.thumb.png.e2414eb7a0c51155a61acfba640649ed.png
image.thumb.png.fe6b57c1f35460c8cbf112d7360ef683.pngZsQ61JqeGkZpEjoD3j07X0T8aBgNCmjIMAYQmLZ_HbbxhSAy2fQ1_aku7JXWuMOq8yvKOk54bcNX5gxFyHvzgljzIoTI2336iiqv9NPipFE_Tbet86lspMQUDrSMNcBrx8Dh2u5Q8BwcQxgekQbhIwQ7-hqrTHGxKib5IORYhLlK6uBNuecvncBNT28h4cK9NV4kRhOiVo3SbEwKEgTg5QpTiiLtz9iJxqw7t4bP6r3h4shMi8Rpi3_HxL32KoF6jgkKlzYD5JVK9shkeTIORrwpcCzAe35YThdrIK-ah9ax1EZ2cwHWC0p9NOEU7O6TbJPEW2RBP7nhELPAIJgvSAKvEI29zbvJfYfdY6XSm4bTXcPBghEX6s4PMlAKVe-qcMS5mSFEB1oTkXd4OyFDGsx2cdBnF6E-YZT8S2IdSvoMAAj8Lk3GzAulTdFmcdHMHMfR6R0Ay1nGNBYATGgaZf3-3AAdoRnqIbqD-Yv0UlVV8aCVkcc2Doylckv7rSFfr4BekMkZLqg7pWdbBFG5Ja07Y5KUpb27PFsvX8TMA6qRtbyfIgL8nvXeCnvjUCj7FHIPrlZuDtRjE41EzlQGAnXwMc5iFOS6ljBWWO-9nsyp9j2_dH6kGWvIAbtQfLoNKJWPL_6w4uUpYt_dShBVzynjLzUqoahW3YNvlUXvDnU7CICaEBiUrmR0azOuOUFIbXwz7YwCf12e_9SpJnzLW9gi=w1794-h1345-no?authuser=0
Edited by JoAnnWodke
to clarify issue
I have about a -48 (guessing) at the back of the house along the fence line. Its a drainage easement.
At the back wall of the house I have about a -24? its kind of steep.
In the front of the house I should have about 3 steps to the front porch so maybe around ??? zero???
When I think I know what I'm doing and give it another try......then everything starts to crumble, like the patio, the drive way ect.
I've walked away from it several times frustrated.
I appricate any helpful advise.
Jo
Good grief.  It took almost 5 minutes for my internet to open just one of your pics!
You need to NOT be "guessing".  Start measuring, then you might be able to deal with your terrain elevations.
But that's NOT your only problem.
I see what looks to be incorrect ceiling heights, and possibly some incorrect roof pitches, too.
  • JoAnnWodke changed the title to changing the terrain after the house is completed
yes Jo_Ann there are several issues, I've not perfected the program, AND FAR from it.
I bought the software and I had to use it quickly as we had already broken ground. I have been able to whip it together pretty quickly. I'm quite happy with the short time I put it together.
The roof is defiantly not correct and ceiling heights as well no doubt. Our builder has 9ft ceiling at the parameter going to 10ft.and the vaulted in the living area.
That is way over my head as is the funky roofline.
butt......Thank you for your help
Eric, I believe I attached the plan correctly, I will review the terrain info. I do appreciate your time
JoAnn
plan to export.dwg
