DWG Export minus the hatches
AlexT8113
Go to solution Solved by solver,
Hi,
I am trying to export my elevations into a dwg file, and I do not want the patterns (brick pattern on walls and asphalt pattern on roof) to get exported. But it does not matter whether I select or don't select the "export pattern lines" choice in the export current view pop up window.
Is there a way to eliminate the patterns before/while exporting? They are converted into CAD lines when exported and it is a mess to delete all of them at that point.
Thanks
Alex
Using Home Designer Pro 2021
