SandraH Posted July 7, 2021 Share Posted July 7, 2021 Can anyone tell me if there is a way to eliminate the space between these tiles? I have created a user generated material, and would like the tile to be continuous across the wall as a backsplash. I have tried offsetting the material, but that doesn't seem to change the white space. I have looked at all the literature, but have not been able to find any info regarding this. May not be fixable based on the pic uploaded TIA Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 7, 2021 Share Posted July 7, 2021 The "White" material is the white border of the imported custom material image. You need to delete the existing imported image and then crop the image so it can then cleanly repeat across a 3D face without the white space, this must be CAREFULLY AND PRECISELY DONE in order to get the desired effect in Home Designer. You reedit the image and then reimport into Architectural as a new custom material. DJP Link to comment Share on other sites More sharing options...
SandraH Posted July 7, 2021 Author Share Posted July 7, 2021 Thanks. I figured that might be the issue, but each upload seems to be different, and some work great, while others end up like this. I'll edit and re-upload. Link to comment Share on other sites More sharing options...
