Remove middle newel post on stair run
jjocsak
I need to remove the center newel from the stair run going to the second floor.
I changed the newel spacing on the second floor railing to remove the middle post. I don't have that option on the stairs themselves.
Is that a limitation on Home Designer Suite or maybe a bug.
It seems as though if I can do what I want on the connected railing on the second floor I should be able to do it on the stars .
Thanks
Jeff
Home Designer Suite 2021
