AngieRobshaw Posted May 1, 2021 Share Posted May 1, 2021 I upgraded to Home Designer 2021 so that I could print in Arch D size. However, I can't seem to figure out how to get the text boxes ,that you put all the blueprint info in, to also change size. Is there an easy way? Thank you Link to comment Share on other sites More sharing options...
solver Posted May 1, 2021 Share Posted May 1, 2021 16 minutes ago, AngieRobshaw said: Is there an easy way? Those are CAD lines. You need to edit them (Stretch CAD etc) to create a new Arch D layout. Save As into the layout template folder for reuse, or if you want this as your default layout template, rename the existing default template and save the new one with the default name. I used Stretch CAD and Point to Point move to resize this in a minute or two. 1 Link to comment Share on other sites More sharing options...
AngieRobshaw Posted May 9, 2021 Author Share Posted May 9, 2021 Thank you Eric. That will work. Link to comment Share on other sites More sharing options...
