JukuApresto Posted April 23, 2021 Share Posted April 23, 2021 Hello, I'm designing my house with a touch of spanish accents exterior. I have difficulty finding 12"x12" or 8"x8" pattern stone/pavel/tile in the catalog for the walkway. All patterns I found are too small. The attached 'desired walkway pattern' looks like stamped concrete, if so how do I replicate that in the software? Any help is greatly appreciated, as well as other suggestions - I'm new, crawling my way through the software. Thank you so much Link to comment Share on other sites More sharing options...
solver Posted April 23, 2021 Share Posted April 23, 2021 15 minutes ago, JukuApresto said: All patterns I found are too small. Using the Adjust Material Definition tool, select a material in a camera view and look at the settings on the Texture panel. You can copy materials from the program library into the user library and make changes creating a new material too. 1 Link to comment Share on other sites More sharing options...
JukuApresto Posted April 23, 2021 Author Share Posted April 23, 2021 Thanks very much for the idea Eric! It worked. What I did via Select Materials, is to copy an existing pattern with a scale of 3 (or whatever factor one desires) to a new one and use it. Link to comment Share on other sites More sharing options...
