NancySnyder Posted April 22, 2021 Share Posted April 22, 2021 When I'm working in Home Designer Pro, I have a new problem (as of a month ago). Every time I save a plan as I'm working in it, the program changes the file name by adding a number at the end. So I end up with multiple files, each taking up an enormous amount of space. For example, if I'm working with a plan file called "U-shaped kitchen.plan", I'll end up with "U-shaped kitchen 1.plan", "U-shaped kitchen 2.plan", "U-shaped kitchen 3.plan", etc. Has anyone else had this problem and do you know how to fix it? I'm currently working in Home Designer Pro 2018 (and yes I know I should upgrade). Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 22, 2021 Share Posted April 22, 2021 46 minutes ago, NancySnyder said: Has anyone else had this problem and do you know how to fix it? I'm currently working in Home Designer Pro 2018 (and yes I know I should upgrade). No, been using the software since 1994 and I have never seen this happen. Makes me wonder what EXACTLY you ARE doing to cause this! DJP Link to comment Share on other sites More sharing options...
NancySnyder Posted April 27, 2021 Author Share Posted April 27, 2021 David, I'm working on a MacBook Air. I merely hit the save icon periodically, to save my work as I'm going along. Then when I go to look in my files, I see that each time I do that, my plan is being saved with a different numeric extension. I'm not doing anything differently that I have been doing for all the years that I've been using Home Designer Pro, but this problem started happening about a month ago. Link to comment Share on other sites More sharing options...
