stairs in split level
Tbone1
nothing I try to do seems to work, stairs don't seem to want to go through wall(s), also not sure I'm using this forum correctly so please bare with me.
in this example lower stairs don't seem to want to through wall to connect to floor and upper stairs have same problem going through wall and connecting to floor above.
Clearly I don't know what I'm doing so could use some help.
thanks
Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using.
You can help everyone by adding that info to your signature (see below for how to turn them on) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Resources for self help:
Home Designer - Getting Started - Setting Preferences and Defaults
You need to add openings manually, just as you would when building the wall.
