KennethEvans Posted April 20, 2021 Share Posted April 20, 2021 I am trying to build a terrain for a lot with a complicated topology. It is next to impossible to distinguish Elevation Data from the rest. I can change the fill but not the line weights. That is, I can change them either in the Display Options or in the Open Object for the object, but they don't change in the UI. In the attached screen dump, the selected line has a line weight of 30 (default was 18), but it isn't any different from the rest. Note that I _have_ redefined the fills for some objects. I do have Line Weights selected on the left. Selecting or not selecting it makes no difference. This is making it very hard to define the terrain. For example I was getting glitches that I finally traced to short stray lines apparently generated when trying to connect splines. I could not see them. Link to comment Share on other sites More sharing options...
Solution solver Posted April 20, 2021 Solution Share Posted April 20, 2021 On 4/20/2021 at 4:41 PM, KennethEvans said: the selected line has a line weight of 30 (default was 18) Expand Make it 60 (just make it more) to see a difference. Link to comment Share on other sites More sharing options...
KennethEvans Posted April 20, 2021 Author Share Posted April 20, 2021 Eric, Thanks. That did it. Had to set it to 200. Not something I would have guessed to do. Makes it much easier to do the elevation, now. Link to comment Share on other sites More sharing options...
