Roof Issues
jnuzzo
My Roof keeps rendering with a weird elevated center section.  I have tried all manner of things to get a gable roof with what are essentially dormers on the front of the house to no avail.  I am new to the software and I am sure it is a setting I'm oblivious to but I was hoping someone could point me in the correct direction.  I have also attached pictures of the general look I am trying to achieve, but as you can see it does not join properly.
I believe I have my signature turned on but if its not showing, I am using HDPro 2021.
Thanks!
Try lowering the ceiling in the space between the gables, or raising the ceiling everywhere else.
Roofs build over rooms and are generally controlled via ceiling heights. You may need to create rooms that do not match the plan to make the roof build, then turn off auto rebuild roofs.
Or, learn the manual roof tools and make it look correct using them.
