Wall Heights
cbo1877
Need to understand how to change wall heights without adding another floor.  Example: Floor height walls are 9 feet want to enclose several walls to continue to under ceiling which is under rafters.  Two walls follow the line of the roof but 1 wall is a gable type and the third is a shed wall.  Cannot get the walls to cooperate.  Have made all attempts to find how to make these needed walls.
Ceiling heights for the majority of rooms, spaces enclosed with walls are controlled by Edit [ Default Settings - Floors and Rooms - Ceiling Height by you. Exceptions to that are set in individual Room Specification Dialog boxes - Structure Tab - Ceiling Height input box. The same is true for floor heights where the first floor is set by default to zero inches but floors can be raised ior lowered by way of the Structure Tab of each Room Specification dialog, take a look.
