Exposed Rafters and Studs
twnctyguy
Is it possible in Home Designer Pro to create walls and ceilings where the rafters and studs are exposed?  (See attached photo.)   I know how to simulate it with the soffit tool but was wondering if there is a particular protocol in "setings" that I'm just not understanding.  I have spent the better part of the afternoon combing through Home Talk and videos, still haven't seen anything that addresses this specific question.  Thanks.
Well, I'm assumed that if I removed the drywall on the ceiling and walls that that would do the trick.  Instead I get a layer of OSB on the ceiling and a flat surface of fir on the walls.  So, color me dumb...I'm stumped!
Have you built wall and roof framing, and set them to display?
That's the default -- you will need to change it to whatever you want.
  • 2 years later...
To which version of the product does this apply?  Chief Architect?  Home Designer Pro or Architectural? I've tried numerous settings and continue to get the OSB when I remove the interior layer of drywall.  "You will need to change it to whatever you want" - where do you do this?  When I look at materials I've tried "Opening (no material)" and I still see OSB.  It is mentioned to build "wall and roof framing", I'm not seeing that as an option.  I have an option to build the roof and have done that with no success at seeing the studs.
