Kurt_B Posted March 23, 2021 Share Posted March 23, 2021 I have a second story deck that I have modeled. When the deck is created using the straight rail tool HD A 2021 generates two rows of deck supports under the deck. I only want one row of supports. How do I delete the extra row or change the settings to only generate one row of posts? Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 24, 2021 Share Posted March 24, 2021 Due to limitations inherent in Architectural, I would suggest that you name the room "Balcony" and then add the support posts manually to suit your purposes. In HD Pro you can manually edit or delete any unwanted footings and posts but not in Architectural or Suite. DJP Link to comment Share on other sites More sharing options...
Kurt_B Posted April 7, 2021 Author Share Posted April 7, 2021 Thank You Link to comment Share on other sites More sharing options...
