How to find what caused an auto generated wall?
tspear
Home Designer Suite 2021
I have a wall which is offset about 5 ft from my exterior wall which is auto generated in the attic.
I cannot find what element is causing this wall to be magically generated in the air for the attic. (I do have a patio with a roof over it, but the patio is much larger than 5ft.)
How do I track the cause down of the auto generated wall section?
Thanks,
1 minute ago, solver said:
Auto attic walls are created above a wall below. Have you tried deleting the wall?
Eric,
I delete the wall, it effectively makes it invisible. I delete the invisible wall and it redraws the wall.
There is no wall underneath it.
Tim
Eric,
I found it, but it was not obvious. It was caused by bad roof settings on the patio using a "Dutch Gable".
I think I will put this in as a feature request to be able to go to the object that "created": the auto generated feature..
Tim
