DanatCV Posted March 18, 2021 Share Posted March 18, 2021 Is there any way to create a doorway that has a drywall wrapped opening? When I remove the jamb from the doorway, the framing studs are exposed instead of applying drywall to cover them. Link to comment Share on other sites More sharing options...
solver Posted March 18, 2021 Share Posted March 18, 2021 Did you add a paint layer to your wall definition? Link to comment Share on other sites More sharing options...
DanatCV Posted March 18, 2021 Author Share Posted March 18, 2021 Yes... set in the defaults as "white" Link to comment Share on other sites More sharing options...
solver Posted March 18, 2021 Share Posted March 18, 2021 That's the problem. Remove that layer and create a new drywall material in the color of your choice. Link to comment Share on other sites More sharing options...
DanatCV Posted March 18, 2021 Author Share Posted March 18, 2021 I'll give that a try. As always, thanks a million Eric. Your assistance is truly appreciated! Link to comment Share on other sites More sharing options...
DanatCV Posted March 20, 2021 Author Share Posted March 20, 2021 Eric, I removed the paint layer from my wall types in my default settings and made sure the subject wall does not have the paint layer, but the problem still exists. Thereafter I tried rebuilding walls after removing the jamb in the "doorway" settings but the results are the same as in my original picture. Additionally, removing the paint layer resulted in the wall framing moving out beyond the drywall plane, making them visible in 3D. Suggestions? Link to comment Share on other sites More sharing options...
solver Posted March 20, 2021 Share Posted March 20, 2021 18 minutes ago, DanatCV said: Suggestions? Make a simple plan -- 4 exterior walls and 1 interior. Place a doorway. If the problem is still there, attach that plan file. Link to comment Share on other sites More sharing options...
DanatCV Posted March 20, 2021 Author Share Posted March 20, 2021 That did the trick, however removing the paint layer from the wall type causes the wall framing to center on the outer plane of the wall, thereby exposing all of the framing. I'll make sure on future projects not to add a paint layer to the wall types so this doesn't happen again. On this project, I'll simply show the jamb in 3D views but removing them from the plan and material list. Thanks for your quick and professional reply! Link to comment Share on other sites More sharing options...
