Floating Building
jwwhitnejj
Hello,  I am a new user of this software and have watched tutorials and read sections of the user guides without resolution of my problem.  I have started to model my home and a detached garage.  The house is elevated six feet (72") higher than the surrounding terrain on a small "plateau".  The detached garage off this small plateau is at the lower surrounding elevation.
I modeled the house and the garage.  Then, I modified the terrain with a "raised region" around the house and brought it up 72".  When I did that, the house became buried six feet down in the ground.  The garage, not in the area of the raised region, sits at the correct elevation.  I then opened the terrain perimeter and under "subfloor height above terrain", I changed it from 0" to 72".  Now, the house sits up on the plateau at the correct elevation, but now the detached garage is floating six feet in the air!  I've wrestled with this for a couple of days and I know there must be a very simple thing that I'm missing an d corrects this, but I cannot figure it out and if anyone knows what I'm doing wrong and can help me, it would be greatly appreciated.
I have the 2021 version of Home Designer Architectural
Thanks.  Yes, I tried that many times and still can't seem to solve it by lowering it, or else I'm not lowering it correctly.  I end up with a very high foundation wall and when I try to lower the floor, it actually raises the foundation rather than lowering the building.  Very frustrating.  What I'm doing is adjusting the stem wall dimension by increasing it to reach the ground.  I look at it in camera mode and see a very high foundation.  I then go back in and adjust other dimensions but with no good solution.
To go back to the original problem, why is it that if I raise the terrain around where I built the house, that the house elevation doesn't automatically raise also?  Not sure why the program wouldn't automatically adjust the house elevation when you raise the terrain around it.
Eric,
Thank you very much for making this tutorial!  It is very informative for me as I am a beginner and as I said earlier, I wasn't able to find a tutorial or instructions on how to make these changes.  I will spend some time working with these dimensions within my model to understand how they are related.  Your tip on resetting the default value seems to be an important point.  Thank you!
Joe
