ZZONNER Posted February 22, 2021 Share Posted February 22, 2021 Having an issue getting a roof panel plan showing the metal roof corrugations so I can design a roof tape heating system. I built the cabin I designed on Home Designer Pro 2019 and its going through its first winter, 12' of snow so far, and the ice dam areas are showing up. How can I print a layout? Link to comment Share on other sites More sharing options...
solver Posted February 22, 2021 Share Posted February 22, 2021 4 minutes ago, ZZONNER said: 12' of snow so far 12 feet of snow? 5 minutes ago, ZZONNER said: Having an issue getting a roof panel plan showing the metal roof corrugations Could you explain what the need is? That is, why you need something showing corrugations? Link to comment Share on other sites More sharing options...
ZZONNER Posted February 22, 2021 Author Share Posted February 22, 2021 I want to visually show the heat tape supplier and the installer exactly where to put the heat tape. The heat tape is integral with a 16" metal panel clip that attaches to the major corrugations of the roof panel, to hide the heat tape. The clip is painted to match the roof panel. If I do a roof panel aerial view, the panel configurations seem to run the wrong direction. SFP-SCH-PBR Shingle Cable Holder Datasheet.pdf Link to comment Share on other sites More sharing options...
solver Posted February 22, 2021 Share Posted February 22, 2021 41 minutes ago, ZZONNER said: Having an issue getting a roof panel plan What's the problem? Link to comment Share on other sites More sharing options...
ZZONNER Posted February 22, 2021 Author Share Posted February 22, 2021 Link to comment Share on other sites More sharing options...
solver Posted February 22, 2021 Share Posted February 22, 2021 I add Standing Seam roofing to a couple of roof planes. Is this more like what you are looking for? Link to comment Share on other sites More sharing options...
ZZONNER Posted February 22, 2021 Author Share Posted February 22, 2021 Yes, I made the same modification and it works. The Corrugated Roof material option runs the rib the wrong way. Glitch in the material default? Thanks. Link to comment Share on other sites More sharing options...
solver Posted February 22, 2021 Share Posted February 22, 2021 15 minutes ago, ZZONNER said: The Corrugated Roof material option runs the rib the wrong way. You can fix that with the Adjust Material Definition tool. Just rotate the pattern 90 degrees. 1 Link to comment Share on other sites More sharing options...
